Mastra11
Jul 07, 2021Apprentice
orbi rbk753 firmware update
Hello, I have a Netgear orbi rbk753 ax4200 system I wanted some information about the firmware update. Currently I have the version 3.2.16.22_1.4.9 for some time indicates to me the version 3.2.18.1_1.4.14 is available is this version stable? can I install it safely? To be honest I am a little afraid to do firmware updates ... How do you update the firmware? I usually do it with PC and Google Chrome by clicking on update all and so update routers and satellites. Thanks for the replies.
If your system is working fine, then you don't have to update.
IF you choose to do so, then you can manually update if your RBR/RBS don't see any update available:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelliteUpdate the RBS first then RBR lastly.
- Mastra11ApprenticeHi and thanks for the reply, Let's say the system works but not great. Sometimes the satellites that are not so far away, so they connect in 5G backhaul, disconnect and then reconnect, then when it happens that the power goes out and then comes back I still have to restart routers and satellites because it struggles to assign IP addresses. Anyway yes if I enter the orbi app or the router gui it notifies me that there is an update. Overall, however, when it is in operation it works well, the WiFi coverage and speed is excellent. thank you.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
