puffo25
Oct 19, 2021Aspirant
orbi RBK753 nightmare: extender keep getting disconnected from access point
I have tried several workaround like assign a static IP address to the extender. No luck. I have downgraded the firmware of Orbi to previous version. No changes (than I have reverted to latest firmware again). I have enable and disable AX (according to Netgear technical support tip), again no changes.
I am totally lost.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Are you referring to the RBR as the 1 AP and the RBS as the extenders?
200 sq meters maybe too small to have the RBR and 1 RBS all running at the same time.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What happens if you turn OFF both RBS and just run the RBR alone?
- puffo25Aspirant
The internet provider is Telecom Italy (TIM). The hub producer is ZTE model X388. I have the latest firmware for the hub.
The router is connected via ethernet with the Orbi access point (only 1/4 feet away). Than the extenders are connected to the Orbi. They are about 40 feet away. Please note: signal is very good (!). Also according to Orbi, the coverage of my apartment is perfect since in terms of square meters this solution is optimized to 325 square meters (mine is 200!).
The firmware for my Orbi is V4.6.5.14_2.0.54.
Again I have not more than 6 visibile networks in my area and my own is the strongest and the others are quite far away and they also use a different channel.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-RouterAlso the distance between the modem and RBR should be 3 to 6 feet from each other.
