Danatt
Jul 07, 2021Follower
Orbi RBK753 wired backhaul slow after power outage
After a power outage I had to re enter the internet setting in my RBR750 because (I don’t know how) the outage changed some values. After this the wired satellite (and the wireless one downstream) were working but at a fraction of the speed of tue router (600 vs 7 mbps download). I reset the whole system but I keep getting the same speeds. Firmware version hasn't changed, it's 3.2.18.1 in both cases.
Maybe it’s worth noting that after resetting the wired satellite and later the wireless one had difficulty syncing to the router and “out of sync” was displayed on the satellite status page (it didn't do it when I installed Orbi for the first time), but after an hour the status changed to “good” and has been so since.
Any tip is appreciated
1 Reply
Try powering OFF all units. Including the ISP modem/ONT for 1 minute.
Power ON the ISP modem/ONT first, then RBR. Check speeds here first.
Then power ON the RBS, one at a time. Then test.
