bremmerd
Sep 03, 2020Aspirant
Orbi RBK753S Upload speed
I just got the RBK753S system. I'm on Verizon Fios with 1gb down/up speed. With my new Orbi router, I am getting over 900 down and 900 up when tested at the router. But when I test on my iPhone 11 Pro, I'm getting 500-600 down and only around 40 up. (For reference, my old router (Verizon quantum gateway) gave me 400 down and 400 up when also tested on my iPhone.)
I'm not that concerned about the drop from 900 down (on router) to 500-600 down (on device), but the drop on the up speed as between router and device makes me think sometthing is configured incorrectly - especially since I was able to get much better upload speeds with my fios router. Anyone know which settings to check? I'm on the latest firmware. I've toggled 20/40 MHz Coexistence based on some other forum posts, but that didn't seem to do anything. Changing wifi channels didn't seem to do anything either.
Thanks in advance.
What are your wired speeds results with a wired PC or laptop connected to the RBR?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYou might try option #3...
What is the connection rate seen on the iphone connected to the RBR? Install wifi sweets spots app on the phone and see the rate.
- bremmerdAspirant
The only way I can connect directly to the Orbi router is with an older computer (10/100 ethernet?) and I am getting in the 90s for both download and upload. Still higher than the 40s that I am getting over wifi for upload speed.
Firmware is 3.2.16.6_1.4.4. I thought that was the latest.
I don't have a dedicated modem. I am connected directly to the Verizon ONT via etherhent cable run from ONT to the Orbi router. I'm not sure how to figure out which ONT I have (but it's wall mounted and internior, for what it's worth). I could be wrong but I didn't think it was a double NAT issue beucase I thought the Verizon ONT just sends out the internet signal like a modem, but maybe I'm misunderstanding how that works. Is it different from ONT to ONT?
When I use WiFi sweetspots, I am getting around 400 download speed. I can't figure out how to use that to check upload speeds - is that possible?
Ok on the ONT. Just making sure there isnt any NAT here. :smileywink:
Wifi sweet spots check the connection rate between the phone and the RBR only. This rate is the connetion rate, like a water pipe connected to a water hose. The bigger the pipe the better, however 400Mbps is kind of low for a newer generation iphone connecting to the RBR.
I believe the iphone should be seeing 1300Mpbs or better.
Does the RBRs web page show the frequency of the phone? Should 5G for 5Ghz.
Not sure if these will help however try disabling AX mode on the RBR,
Try changing CTS to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
Do you have Armor enabled?
