BlackBear51
Apr 28, 2026Guide
Orbi RBK852 – Wired via Satellite drops from ~700 Mbps to ~50–80 Mbps until reboot
I’m trying to figure out an issue with my Orbi RBK852 setup. I have gigabit fiber (Verizon), and when everything is working properly I get around 600–700 Mbps up and down, which is great. The pro...
- Apr 28, 2026
Might try a different cable if you have something just to test to see if the WAN port can get back to 1000Mpbs.
Apr 28, 2026Guru - Experienced User
BlackBear51
Apr 28, 2026Guide
Alright, I swapped it with a KASIMO CAT8 - 2000MHz S/FTP PIMF Patch Cable PVC... It switched to 1000M/Full and speeds went up to 500/600 Mbps. I will keep eye on it and see if it goes down in the next couple of days.
- FURRYe38Apr 28, 2026Guru - Experienced User
Ok, let us know if you see this again.
