HerveB1
Dec 14, 2019Tutor
Orbi RBK852 - No way to have separate SSIDs for 2.4GHz and 5GHz bands- No work-around, it seems
I just got an Orbi RBK852. My plan was to replace two older ASUS routers in an AIMesh configuration with the new Orbi that support Wifi 6 as the ASUS devices have been unstable. I used to have older ...
HerveB1
Dec 15, 2019Tutor
I used to have RBK50 router in mesh node. I followed the work-around to split the SSIDs. It worked just fine.
I just configured two ASUS GT-AX11000 in a mesh configuration. No work around need to set up separate SSIDs. The interface offers option to turn on/off smart connect and to specify separate SSIDs.
ASUS gives the option. Netgear could do the same. BTW, their others routers give the option if I recall.
Dec 15, 2019Guru - Experienced User
Just be cause one Mfr offers it doen't mean NG has to.
Users have been asking Since Orbi AC first appeared. NG doesn't seem to budge on this officially. Both Orbi AC and AX work for me with signal SSIDs. Not issues. NG offers disabling of the frequency SSIDs temporarily to help get some IoT connected. That is a IoT mfr limitation on there setup software however.
I would not look forward to seeing this on AX. Maybe in time if NG opens up telnet options. However if they don't support it in the telnet, might not see it at all.
Can post your request here though:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Good Luck.
