MARLYLEROI
Jun 19, 2025Tutor
Orbi RBK852 -Unable to Reconfigure System (Orbi not found)
Hello, My setup: I’m using the Orbi AX6000 Mesh WiFi System (RBK852) – Orbi 850 Series Tri-Band WiFi 6, 2-pack. I also have a Mac and an iPhone. Since yesterday, my Orbi network no longer br...
- Jun 19, 2025
I did reset a second time and it is OK. Thank you all. SOLVED.
michaelkenward
Jun 19, 2025Guru - Experienced User
MARLYLEROI wrote:Note: The Freebox SSID and the Orbi SSID have different names (no naming conflict).
You have a Freebox device that is also a router?
Two routers on a network are bad news:
What is Double NAT? | Answer | NETGEAR Support
Then there is this:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
Can you access the Orbi from a web browser and the graphical user interface (GUI)?
Just another user with time on their hands.
MARLYLEROI
Jun 19, 2025Tutor
Thank you Michael.
Here is my 2 Sanders To your 2 questions
freebox is The device of my internet provider in France. This is Not a rooter To be clear. Sorry I should have mentionnes on my forts post
i can NOT access web gui from web browser.
