MARLYLEROI
Jun 19, 2025Tutor
Orbi RBK852 -Unable to Reconfigure System (Orbi not found)
Hello, My setup: I’m using the Orbi AX6000 Mesh WiFi System (RBK852) – Orbi 850 Series Tri-Band WiFi 6, 2-pack. I also have a Mac and an iPhone. Since yesterday, my Orbi network no longer br...
- Jun 19, 2025
I did reset a second time and it is OK. Thank you all. SOLVED.
MARLYLEROI
Jun 19, 2025Tutor
- FURRYe38Jun 20, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
