Whoskyle's avatar
May 15, 2022
Orbi RBK852 Disconnecting Everyday
Hey All,
Recently every early morning around 0600 the Orbi loses internet connection. I am running Century Link Fiber 1GBPS running from a ONT to the Orbi.
Rebooting the Orbi works and then the internet connects again, however this is cumbersome and also annoying. My cameras disconnect and won’t record during this time, anyone had this before and or know of a solution?
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor
    Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    • Whoskyle's avatar
      Whoskyle
      Tutor
      It’s a Calix Gigapoint 803G
      My Orbi is running 4.6.8.2
      I have done all the other steps as well
      • FURRYe38's avatar
        Does the front LED on the RBR turn PINK when this happens?
        What is the CAT# lan cable between the ONT and RBR? CAT6 is recommended...
