rabonbryan
Aug 04, 2022Aspirant
ORBI RBKE963 randomly disconnects from Internet
I have suffered random disconnects from the first day I installed this router. My Comcast XFI gateway never loses it's Internet signal as the light on my Comcast gateway stays on constantly while th...
Mikey94025
Aug 05, 2022Hero
I have the same Orbi RBKE963 + extra AXE satellite connected to the Xfinity XB7 gateway (not the latest, which is XB8 and gradual rollout) in bridge mode. I do not experience the daily disconnect problems you are reporting, so let's check if there are any differences.
- Exactly which gateway do you have? Pictures are here: https://www.xfinity.com/support/articles/broadband-gateways-userguides. The XB7 has a slightly different top holes pattern than the XB8,
- How is your Orbi router connected to the gateway? Is there a switch or anything else in between?
- Have you tried swapping the network cable from Orbi to gateway (just in case)?
- What do you do to fix the Orbi connectivity when the disconnect occurs? Do you go to orbilogin.com and press a Connect button and it recovers immediately? Describing your recovery procedure may help to isolate the nature of the issue.
- As per the other reply, try switching to AP mode after taking your gateway out of bridge mode.
- You may have an Orbi hardware problem, you can request exchange under warranty (longer than tech support 90 days).
rabonbryan
Aug 05, 2022Aspirant
Thanks for your reply.
I have the XB7-T gateway
Connected with a single Cat5 cable, no switch or anything.
Gonna switch the cable as soon as I hit send so we can check that off the list. Stranger things have happened...
I don't do anything to fix the disconnect. I learned over time that it comes back by itself in approximately five minutes.
Also, last weekend I factory reset Orbi to no avail.
I appreciate your ideas.
I will set the gateway back to router mode today. WiFi is not enabled of course.
Thanks a lot.
- FURRYe38Aug 05, 2022Guru - Experienced User
So CAT5 is only officially rated for 100Mbps. Lets try a CAT6A STP cable between the modem and RBR....
- rabonbryanAug 05, 2022Aspirant
I used to have a ton of ethernet cables. I was in IT for 18 year before I retired five years ago.
I could only find two sad little cables with no markings on them at all so I just used it...
I just ordered the proper for sure cable from Amazon for delivery tomorrow.
The only way to be sure.
I just got lazy.
Thanks for pointing that out.
For what it's worth I have a 600MPS account with Comcast and the speed test this morning went to 702. I'm assuming it wouldn't do that with a real CAT5?
When I said "CAT5" cable earlier I really didn't know what it was.
I'm going to switch to that cable when it arrives and wait for it to fail before I reconfigure the gateway so I will know for sure which troubleshooting steps works rather than doing two or more at a time.
Thanks for your help.
I appreciate it!!
CAT5 is only supporting of 100Mpbs. CAT5e was good up to 1000mpbs. CAT6 is recommended for most 1Gb RJ45 ports on current LAN devices. With recent increase in connection rates 2.5 and 10Gb, CAT6A STP cables are recommended as the higher speeds can be effected by lesser CAT versions of cables. I ran in to a odd reboot issue with my 9 series connected to my CAX80 while using it's 2.5Gb WAN port. I had been using CAT6 UTP cables. After getting a CAT6A STP cable in, the 9 series returned to good normal operation. So I kind of keep in mine that 1000Mpbs ports CAT6 UTP should be good up to this point. 2.5Gb and higher ports, I recommend CAT6A STP cabling. It's supporting of up to 10Gb connection rated speeds.
