rabonbryan
Aug 04, 2022Aspirant
ORBI RBKE963 randomly disconnects from Internet
I have suffered random disconnects from the first day I installed this router. My Comcast XFI gateway never loses it's Internet signal as the light on my Comcast gateway stays on constantly while th...
Mikey94025
Aug 05, 2022Hero
I have the same Orbi RBKE963 + extra AXE satellite connected to the Xfinity XB7 gateway (not the latest, which is XB8 and gradual rollout) in bridge mode. I do not experience the daily disconnect problems you are reporting, so let's check if there are any differences.
- Exactly which gateway do you have? Pictures are here: https://www.xfinity.com/support/articles/broadband-gateways-userguides. The XB7 has a slightly different top holes pattern than the XB8,
- How is your Orbi router connected to the gateway? Is there a switch or anything else in between?
- Have you tried swapping the network cable from Orbi to gateway (just in case)?
- What do you do to fix the Orbi connectivity when the disconnect occurs? Do you go to orbilogin.com and press a Connect button and it recovers immediately? Describing your recovery procedure may help to isolate the nature of the issue.
- As per the other reply, try switching to AP mode after taking your gateway out of bridge mode.
- You may have an Orbi hardware problem, you can request exchange under warranty (longer than tech support 90 days).
rabonbryan
Aug 07, 2022Aspirant
So, sadly switching out the cable with a Cat 6e STP 10G between the Orbi and the xFi gateway did not change anything.
But, I verified an odd situation that I suspected was occurring.
Today I was streaming a totally LIVE event on my wired desktop Windows 10 computer while browsing the evil Internet on my other screen and all of a sudden the browser said "No Internet Connection" and stopped responding.
The light is solid red on the Orbi.
When the system disconnects it always takes about five minutes and it reconnects on it's own.
The really odd thing is the live streaming video and audio never missed a beat during the entire five minutes or so until the browser responded and I could browse the Internet.
Every time things start working again the red light is still on for about a minute also..
Crazy!
What do you make of that?
I don't understand that at all.
I appreciate your thoughts on this as I have no idea what to do.
PS, I have factory reset the system and started over to no avail.
Thanks!
- plemansAug 07, 2022Guru - Experienced User
Did you try it as I suggested at the start?
With the orbi in access point mode and the xfi gateway in router mode (wifi disabled)
- CrimpOnAug 07, 2022Guru - Experienced User
I do not recall every reading an explanation for what causes the router to turn on the magenta light or for computers/browsers to decide there is "no internet". From this description, one might infer the issue is not loss of connection, but rather loss of some specific capability (maybe DNS resolution? Maybe pinging netgear.com?)
- FURRYe38Aug 07, 2022Guru - Experienced User
Are you using the DMZ in the ISP modem?
Wanna try enabling email logs to see if you see a change in this?
Crazy!
Thanks!
