mtrummer
May 12, 2025Aspirant
Orbi RBR 750 and VPN on MacOS
Hi, I have some issues setting up the VPN client on MacOS. On both my iPhone and my Windows computer it was very easy, but even when I use the suggested app TunnelBlick and import the non-windows...
May 14, 2025Guru - Experienced User
What Apple computer model do you have? Desktop or laptop?
Be aware that with newer OSX versions, Apple has implemented the same MAC Address randomizer in the OS and is enabled by default. I happened to stumble across this when I saw an unknown MAC device/address on my network. Had to use wireshark to track it down, After it said it was an Apple device, I only have a few, I found that my Mac Book Pro with OSX 15 loaded had this feature. Once disabled, Mac Book appeared on network correctly. So something to check for with in OSX.
- mtrummerMay 14, 2025Aspirant
I have a MacBook Air M4. The MAC address is set to fixed private Wifi address, but not rotating.
