RSMV's avatar
RSMV
Tutor
Apr 25, 2022
Orbi RBR 750 is very unstable
Have an RBR 750 with 3 satellites and a few things hardwired into the ports.  It's wired into the Comcast cable modem.  The 750 frequently (~5X week) goes magenta.  There is still internet at the Cable modem, as I can make use of the Comcast wifi while the Orbi is power recycling.  This is a recent (last 3 months) phenomenon; for the first year or so the system was rock steady.
Any ideas why it has grown unstable?
Thanks
RSMV
  • FURRYe38's avatar
    Which unit shows PINK in front? RBR or RBS or do all unit show PINK?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • RSMV's avatar
      RSMV
      Tutor
      Current firmware is 4.6.7.13
      The ISPs modem is a generic xFinity modem.  Doesn't have a MFR or model# that is identifiable from label on the bottom
      The RBR shows pink.
      Yes as to the power cycle on the modem and RBR, tho I don't know any way to "turn off" either device other than unplugging them.
      thanks
      • FURRYe38's avatar
        There a picture of this modem? Need to get more info on this if possible
        If the RBR shows pink, only a few items that can cause this, bad cable between the modem and router, loss of connection with the modem, or modem isn't giving good ethernet services to the modem or modem is having problems.
        What CAT# LAN cable is being used between the modem and router?
