Iggy_Marley
Aug 04, 2024Aspirant
Orbi RBR 750 very unstable connections with things connected through satellite
I started noticing that i was getting the correct ping speeds in some parts of the apartment and horrible in others. My apartment is about 1600 sq ft with drywall, and I use one satellite to go along...
- Aug 06, 2024
Try setting manual channel 1 on 2.4Ghz and 40 channel on 5Ghz.
Does this happen with the RBS turned OFF?
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Iggy_Marley
Aug 06, 2024Aspirant
So the firmware cersion is V7.2.631_5.0.24
2.4 ghz channel is in auto
5 ghz channel is 48
The modem is a nokia g-2425g-b
As said in another post i have two neighbors on my floor, 3 below and 3 above but the building structure is solid concrete.
Look forward to your feedback!
5 ghz channel is 48
Aug 06, 2024Guru - Experienced User
