Rod1971
Jan 14, 2024Follower
Orbi RBR 850 - Hive Radiator Valve
Hi All,
I am trying to connect my Orbi to my hive radiator valve but can’t.
I can’t connect my Orbi to any 2.4ghz, this is set in my advanced set up.
Can anyone help?
1 Reply
The technical specs on the Hive Radiator valve say that it connects using Zigbee:
This is from: https://www.hivehome.com/shop/smart-heating/hive-radiator-valve
Orbi WiFi routers do not support Zigbee. If the smartphone app is to control the valve using WiFi, there must be a Zigbee hub connected to the WiFi system to act as a bridge.
Is the Hive Hub already connected to the router with an Ethernet cable?
https://www.hivehome.com/shop/connectivity/hive-hub
