CrazyEddie
May 01, 2023Apprentice
Orbi RBR 850 as AP conflict with Proton VPN
Many thanks to CrimpOn and FURRYe38 for their replies to a prior post (https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Protectli-vault-and-Orbi-850-compatibility/td-p/2304455) in which I was planning for adding a Protectli Vault as a hardware firewall, running OPNsense, in front of my Orbi 850 mesh system. I have a follow-up issue.
The firewall and OPNsense have worked fine with the Orbi as an AP - EXCEPT when I use Proton VPN thru the firewall. When I use the VPN, the Orbi WiFi connection works, but is extremely volatile. It will connect, have great speed, but then fail 30 seconds later, and then work again another 30 seconds after that. It is a struggle to maintain WiFi for long enough to disable the VPN in OPNsense.
I used a Beryl AX as an alternative AP and it worked without any issue, so it seems like it's the Orbi (or my failure to do something in the settings). Can anyone think of a setting on the Orbi that I need to change? It's in AP mode. Someone suggested I change back to router mode, but I'd prefer not to have two routers, and if it works for the Beryl AX, I'm hopeful it can be figured out for the Orbi (especially since I have three units....)
What a cute little travel router. (Beryl AX) How is it connected to the OPNsense firewall? (Ethernet or WiFi?) and is the Beryl in Access Point mode?
Probably not much to change on the Orbi settings when in Access Point mode. It is surprising that the Orbi WiFi signal would actually switch on and off. (for real? device wireless settings report "not connected", but then connect again in 30 seconds?)
What happens when the VPN feature is not active on OPNsense?
- CrazyEddieApprentice
Thanks for the reply. The size is pretty convenient for travel. It's new to me and I've only used it once at a recent hotel stay. At home I connected the Beryl via ethernet in the same Protectli port to which the Orbi router (in AP mode) was connected. I believe using the ethernet connection puts the Beryl in the equivalent of access point mode automatically. (The other choices are "repeater" "tether" and "cellular".)
That's my non-technical explanation for what happens (when using the Orbi) as I watch the MacBook Air Wi-Fi icon in the top of the screen. It's connected, then I see the "bars" drop, then nothing is shown, then it connects again. (I have the same problem with other devices, so it's not just the MacBook.) also try to run Speedtest and periodically will then get a message "Error Test failed to complete. Check your internet connection and try again." Running ifconfig.me in Terminal produces "curl: (6) Could not resolve host: ifconfig.me" If there is a better place to look (in logs?) for an explanation, please point me in that direction.
Everything works like a charm. My current speeds when connected to the Orbi are 298/38 (and that's with using Proton VPN on my device - not the firewall). Without the VPN running on the device, the speeds are 430/39.
My sense from reading the User Manual (https://docs.gl-inet.com/en/4/tutorials/internet_ethernet/ ) is that the Beryl remains in router mode, providing all sorts of router functions no matter how it is connected to the primary system.
An easy test is to look at the IP address that a device gets when it is connected to the Beryl WiFi compared when connected to the Orbi WiFi. If they are the same, then the OPNsense firewall is assigning IPs directly to devices no matter how they are connected. If they are different, then the Beryl has created a separate LAN subnet.
