Ausfrenchy
Sep 24, 2021Tutor
Orbi RBR350 ethernet not working with wifi OK
Model RBR350 Firmware V4.4.0.10_2.10.63 Successfully set up with (PPoE) VLan and wifi performance is as good as native internet connection. But i cannot get hardwire ethernet connection to work at ...
- Nov 29, 2021
Further update on this issue.
i have just received a Beta firmware update for trial.
Looks to have fixed the problem, all working as expected now.
Sep 24, 2021Guru - Experienced User
Check NGs download site for FW updates:
https://www.netgear.com/support/product/rbk352.aspx#download
Ausfrenchy
Sep 24, 2021Tutor
Hi, have just done a full reset and setup.
Problem is still there.
Also checked firmware versions - all up to date.
- FURRYe38Sep 25, 2021Guru - Experienced User
I commend you contact NG support and ask for help and information regarding this. Ask about an RMA. Seems that the RBR maybe faulty and needs replaced.
