TherJ
Nov 27, 2021Aspirant
Orbi 350: Wired connection cannot access internet. Wifi works
I have an Orbi RBR 350. The wifi works well however, the wired connections do not work.
When I connect a laptop via ethernet to the router, it shows up as 'connected to the internet via ethernet' in Windows Network settings. I can also connect to the router via the laptop through www.orbilogin.com and in here it says the internet connection is 'good'. However, I cannot access the internet through any of the browsers on the laptop (Chrome / Explorer). I have tried two laptops.
And both laptops have there networking settings set for obtain IP addressing automatically?
Do these laptops work ok with being wireless?
Be sure to swap LAN cables with a good working cable. CAT6 is commended.
