Ausfrenchy
Sep 24, 2021Tutor
Orbi RBR350 ethernet not working with wifi OK
Model RBR350 Firmware V4.4.0.10_2.10.63 Successfully set up with (PPoE) VLan and wifi performance is as good as native internet connection. But i cannot get hardwire ethernet connection to work at ...
- Nov 29, 2021
Further update on this issue.
i have just received a Beta firmware update for trial.
Looks to have fixed the problem, all working as expected now.
Ausfrenchy
Sep 24, 2021Tutor
Hi, have just done a full reset and setup.
Problem is still there.
Also checked firmware versions - all up to date.
Sep 25, 2021Guru - Experienced User
I commend you contact NG support and ask for help and information regarding this. Ask about an RMA. Seems that the RBR maybe faulty and needs replaced.
- TherJNov 27, 2021Aspirant
Did you get this resolved? I have similar issue.
- FURRYe38Nov 27, 2021Guru - Experienced User
- AusfrenchyNov 28, 2021Tutor
Hi , issue yet to be resolved. Raised this problem with Netgear and had confirmed as a known problem. Waiting for firmware update to resolve. I have reconfigured my device as an AP and it seems to work ok but disappointed that will not work as I originally wanted.
- AusfrenchyNov 29, 2021Tutor
- FURRYe38Nov 30, 2021Guru - Experienced User
Good to hear. Glad NG got it fixed.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
