Ausfrenchy
Sep 24, 2021Tutor
Orbi RBR350 ethernet not working with wifi OK
Model RBR350 Firmware V4.4.0.10_2.10.63 Successfully set up with (PPoE) VLan and wifi performance is as good as native internet connection. But i cannot get hardwire ethernet connection to work at ...
- Nov 29, 2021
Further update on this issue.
i have just received a Beta firmware update for trial.
Looks to have fixed the problem, all working as expected now.
Sep 25, 2021Guru - Experienced User
I commend you contact NG support and ask for help and information regarding this. Ask about an RMA. Seems that the RBR maybe faulty and needs replaced.
TherJ
Nov 27, 2021Aspirant
Did you get this resolved? I have similar issue.
- FURRYe38Nov 27, 2021Guru - Experienced User
- AusfrenchyNov 28, 2021Tutor
Hi , issue yet to be resolved. Raised this problem with Netgear and had confirmed as a known problem. Waiting for firmware update to resolve. I have reconfigured my device as an AP and it seems to work ok but disappointed that will not work as I originally wanted.
- AusfrenchyNov 29, 2021Tutor
- FURRYe38Nov 30, 2021Guru - Experienced User
Good to hear. Glad NG got it fixed.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - Whitie25Dec 28, 2021TutorAny ETA on that new firmware? I’m having this issue too.
