satelly
May 27, 2022Aspirant
Orbi RBR350 losing 2.4 GHz signal
Recently have been moving from 1 part of the house to another which is serviced by the satellite node, I lose internet connection for about 30 seconds. Losing at the Wifi icon on my notebook, I notice it is searching and reconnecting to the Wifi.
I logged into my Orbi satellite and noticed that the 2.4GHz signal says Disabled. The only way to turn it on is either reset the satellite or go to the main router and turn off and then turn on the 2.4GHz option. Interestingly it only affects the main Wifi and not the Guest Wifi.
I have confirmed the above using Wifi diagnostics and it clearly shows there is no 2.4GHz signal from the satellite for the main Wifi but it is present for the Guest network and for the main router.
I have tried resetting the satellite pressing with in the pin hole several times. It initially shows the 2.4GHz signal and then about 30 minutes later, it is lost.
Any ideas
what firmware version are you on?
Have you tried changing which 2.4ghz channel its broadcasting on (for the router)?
- satellyAspirant
On V4.4.0.10 which is apparently the latest official firmware, although reading the forum, some people have obtained newer versions from Netgear. Have tried the standard channels, 1,6 and 11with same result.
sounds like you've reset the satellite but did you factory reset the router?
