HisRaven's avatar
HisRaven
Follower
Jul 04, 2021
Orbi RBR350
Hi guys, I'm not technically minded so please bear with me. Lost power for almost 48hrs and when everything came back on all technology is buffering. I can't watch any apps on TV, Chromecast, PS4 freezes constantly, I'm even writing this using phone data. There is a 'Sync' button on the Orbi and satellite, which I did try, that made the buffering less, however it's still buffers every few minutes and lasts about 20sec or so.
It was a mission setting Orbi up originally as our phone company purposely tries to block 3rd party, so I don't want to factory reset as I'm worried that'll take me back to square one. I'm really out of my depth so any help would be appreciated.
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you.
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    • Rick1975's avatar
      Rick1975
      Changing channel manualy on 5G is not possible at rb350
      Only on 2.4.
      Afterchanging manualy channels, the sattelites don't change to the same channel most off the time.
      Result a faulty system that is not working till you start all setup all over again.
      Be aware!!
