bc87swa's avatar
bc87swa
Orbi rbr750 and Nintendo switch problems
edited to add...my model isn't selectable above. We have the RBR750
Hello, my kids both have the Nintendo Switch and we are unable to get either console to connect to the Orbi RBR750 wirelessly. We have tried every method of reset including wiping one back to factory settings, and disabling the 5hz broadcast. Any ideas? Very frustrated. Every other device in our house works just fine. We are next to the router and speed isn't an issue...
  • FURRYe38's avatar
    Where are you disabling the 5Ghz broadcast at? I believe that disabling of SSID broadcast is not supported on Orbi AX system.
    You can disable AX mode on both radios.
    Try setting CTS values from 64 go 2347?
    • bc87swa's avatar
      bc87swa
      Firmware Version
      V4.6.3.7_2.0.49
      We are using the Charter Arris TM1602 with the Orbi RBR750
      We just disabled the 5hz on the routerlogin.net for the device.There is a box under the wireless tab to enable each bandwidth broadcast. We just turned of the 5 and tried to connect. Still didn't work....and I'm not sure what the CTS is? I know just enough to be dangerous. Haha.
      • FURRYe38's avatar
        Would you please post a screen capture of this places where your disabling the 5Ghz broadcast so we are sure what your disabling.
        Please use the Choose File button on your next post to attached the screen capture file.
        CTS is under Advanced Tab/Advanced Settings/Wireless Settings
