Clakhu's avatar
Clakhu
Orbi rbr750 geofencing issue
Hi, is anyone experiencing geofencing issues with their Orbi products?
3 of my apps that control heating and security relies on geofencing. When I’m at home those apps notify me that I’ve left the vicinity and then I’m back home.
As soon as my WiFi is turned off my products can locate me accurately but not on my Orbi. I’ve also check for firmware updates, I’m on the latest version.
Question for the community; is anyone else having the same issue where their Orbi is changing their location and if so is there a fix?
  • My point exactly.  Once the phone running the Arlo app learned where the WiFi system was (for 9nine months), it took some time for it to "re learn" the new location (back home again).  Now that the app has adjusted, there is nothing else required.
    If you ever feel the urge to "do something goofy", I'd love to hear what happens if you perform that experiment.
  • FURRYe38's avatar
    I use NEST to control my central air system. No issues.
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    Something to contact the Mfr of your central heating system about and ask them since that there product.
    • Clakhu's avatar
      Clakhu
      Thank you. It’s affecting my Tado heating system, Arlo and alarm systems. One turned off randomised IP on my iPhone. Firmware version is 4.6.14.3 and I’m with Vodafone in the uk. When I’m using my ISP router (Orbi disconnected) I have no issues which makes me think it’s the Orbi sending my phone’s location all over the place.
      • FURRYe38's avatar
        Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
        Try option #2 first...or #3
  • CrimpOn's avatar
    CrimpOn
    It would be helpful to know which apps are involved. (so that we can look at their setup instructions to see how they define geofencing.)
    I very much doubt that the Orbi router has any part in how these apps determine "Where am I?"
    For example, using my desktop computer connected to the Orbi, I went to this web site: https://www.where-am-i.co   Gave it permission to "Know my location" and observed where it said I am, including the actual street address and the location of my IP address.  Both were completely incorrect.
    This app https://www.gps-coordinates.net/my-location also returned the same location as the first, both incorrect.
    As did this one: https://www.mapdevelopers.com/where-am-i.php
    And this one: https://mylocationnow.io
    Wikipedia seems to think that most geofencing is based on a device having GPS capability.
    https://en.wikipedia.org/wiki/Geo-fence
    Since my desktop computer has no GPS capability, those web sites are relying on something supplied by the Internet Service Provider (Spectrum cable, the brand name of Charter Communications).  It would appear that there is no directory which relates IP addresses to physical street addresses.  (Makes one wonder how those geeks on television programs know exactly where people are.)
    Were I programming a geofencing app, I would probably set it to say I am "home" any time the device is connected to my home WiFi system.  If not connected to my home WiFi, then I must be "not home".  Clearly, mobile devices can save credentials for any number of WiFi systems (home, office, Starbucks, relative's house, etc.).  Just being connected to WiFi should not be enough to conclude, "I'm home."   Is it possible those apps were set up using the ISP router?
    Perhaps one experiment could be to disable WiFi on the iPhone.  Walk around the block and see if those apps know when you return home.
    Now, to look at Arlo (formerly part of Netgear) and Tado.
    • Clakhu's avatar
      Clakhu
      Thank both for your suggestions.
      The double nat may have been part of the issue. My ISP router cannot be turned directly into a bridge however I did turn off the WiFi which stemmed the problem temporarily.
      Checking a few ‘what’s my address’ sites it was sporadic but one was if my previous address.
      Just to note, and maybe I should’ve mentioned it earlier, but I moved home last week bringing my Orbi with me.
      With further googling there’s a possibility my Orbi was holding onto my previous location?
      I found this: https://support.google.com/maps/thread/151298153/maps-keeps-thinking-i-m-at-my-old-home?hl=en
      Not sure if this is useful or relevant but I thought I’d share it.
      My geo fencing has seemed to calm down and back to expected behaviour.
      • FURRYe38's avatar
        Just turning OFF the wifi radios on the ISP router doesn't stem the doubt NAT issue. To better help with this, be sure you use the ISP routers DMZ or IP Pass-thru for the Orbi router to better ensure there is seamless internet transition from the ISP router to the Orbi router and avoid any odd internet service issues. DMZ or IP-Pass-thru helps with double NAT issues.
