LAUG1
Sep 08, 2025Aspirant
Orbi RBR750 Lost SiriusXM Access
Orbi RBR750 (WiFi 6 AX4200) can no longer access SiriusXM radio through my Russound MBX-PRE Streamer
LAUG1
Sep 09, 2025Aspirant
Thanks for the help. Here’s where I’m at… I can currently stream Tune In & Spotify radio, no longer SiriusXM. Have contacted both Sirius & Russound tier 3 tech support, no solutions. Have tried the following:
- Factory reset Orbi Router and Russound Streamer
- Rebooted several times
- Tried both wired and WiFi
- Tried DCHP & Static
- Tried the following in the Router Admin page:
- Different Internet IP addresses (Google & Cloud)
- Disabled AX
- Turned UPnP on/off
- Tried using a static route to Sirius
- Using Auto channel. Will give manual channels a try
- Router firmware V7.2.7.15
- GigaPoint Modem - GP1101X
- 1 Satellite (RBS?) Same issue with Satellite power off
Sep 09, 2025Guru - Experienced User
Something else to give a try, Test the SirusXM device on the RBRs IoT network then try the RBRs DMZ for the IP address of the SirusXM device as well.
Also try using some custom DNS like cloudfare or Quad9.
Also check to see if IPv6 is enabled or disabled. Try disabled.
