Red5694
Aug 16, 2023Follower
Orbi RBR750 not allowing podcast
I am having an issue with my Orbi RBR750 not allowing Apple podcasts to play on wifi. It is also blocking a certain website from loading.
If I go to cell data on my phone everything works fine but when I am attached to the network, nothing.
I'm not a wifi genius so if anybody has any suggestions let me know.
Thanks
1 Reply
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connectedBe sure to disable any MAC Address randomizers while at home:
Armor, Smart Parental Controls or Circle, Traffic Meter.
