WAccountHolder
Oct 11, 2024Aspirant
Orbi RBR750 reboots everyday
I have the RBR750 Router with 2 satellites. Since last August, the router would reboot on a daily basis. The light on the router would turn purple, followed by white. I seen solutions on the web where you would route the logs to an email address to fix it. I tried logging into the admin account at orbilogin.com to change the settings, but it just times out. I remember being able to log into the admin account before. Has there been an update pushed to the router to break this feature? What can I do to fix it?
Are you sure its rebooting? Usually when its magenta, its lost its ip address.
This tends to be because of a internet issues.
What modem/gateway is the router connected to?
- WAccountHolderAspirant
Sorry I should not have used the word "reboot". However, I find it strange that the router losses internet connection everyday at about the same time, but it reconnects immediately. I would lose a few minutes of connection time. The issue could be with my internet provider (Spectrum), but I want to exhaust all avenues before contacting them. I do find it concerning that I can no longer access the admin login to the router.
what modem/gateway do you have from spectrum?
