Retired_Member's avatar
Retired_Member
Oct 01, 2021
Orbi RBR750 Teardown
Does anyone know how to remove the backplate to the RBK753S.  I've been searching and can't find it anywhere online.
TG
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you.
  • FURRYe38's avatar
    I think there maybe some screws under the rubber feet on each side...
    I've never taken one of these appart.
    There a reason why your asking this?
    • Retired_Member's avatar
      Retired_Member
      Mine overheats and loses connection at 50mbps.  I wanted to expose the heat sink and put a fan on it.
      • FURRYe38's avatar
        Best way i found to add forced air to any router, place a USB laptop cooler fan under the RBR. Works well.
        How long have you had this unit?
