Joemorris373
Jan 22, 2026Aspirant
Orbi RBR750 wifi speed
I have an Orbi RBR750 with 1 satellite. Just upgraded to 1gb fiber internet. Speeds with a wired connection are in the 900's Gbps but wifi speeds tested with a Galaxy S25 are in the 400's. Firmware i...
CrimpOn
Jan 22, 2026Guru - Experienced User
If the S25 connects using WiFi6 (802.11ax), I would expect to see speed closer to 700Mbps. Does the phone (or the Orbi) indicate that the connection is WiFi5 or WiFi6?
(the WiFi symbol often has a tiny number to show the connection method)
Joemorris373
Jan 23, 2026Aspirant
It is connected to wifi 6.
