Joemorris373
Jan 22, 2026Aspirant
Orbi RBR750 wifi speed
I have an Orbi RBR750 with 1 satellite. Just upgraded to 1gb fiber internet. Speeds with a wired connection are in the 900's Gbps but wifi speeds tested with a Galaxy S25 are in the 400's. Firmware i...
Jan 23, 2026Guru - Experienced User
A couple thoughts.
- Why do you want faster speeds on a mobile device? 4k streaming only takes 25-50mbps.
- The 752 system wasn't the fastest system. It was a base model with dedicated backhaul (wireless connection between router---satellite). Its 5ghz fronthaul was only 1200mbps with a 2x2 antenna configuration. Most test that I seen testing during performance reviews were in that 500-600mbps range. And with only a 2x2 5ghz connection, it left some performance on the table.
- What modem is it connected to?
- what speeds do a wired device see? Wireless is hard to judge as many things impact performance. Such as distance, interference from other signals, network congestiong, etc. So while its nice for a baseline, it isn't the best way to test.
Joemorris373
Jan 23, 2026Aspirant
It is connected to an Adtran ONT and consistently get in the 900's with a wired connection
