Zayra
May 16, 2022Initiate
Orbi RBR750 Won’t Connect To Router
On my App, I show a notice that I am not connecting to the router. I’m on the same wifi, I’ve reboot the router, then did a full reboot with the modem and router as well. I cannot check for firmware u...
May 16, 2022Guru - Experienced User
so if you're actually in the orbi ax forum, you'll see a notice at the top of a current issue with the app.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/bd-p/en-home-orbi-ax
Some were able to fix it by factory resetting and reinstalling using the web browsers. Others have just decided to wait for the update to fix it. kind of up to you which route you go
- ZayraMay 16, 2022InitiateThank you, I guess Netgear created a mess for many of us.
