Smam_berg's avatar
Smam_berg
Orbi RBR750
How do I get the orbi app to detect my orbi network? I have tried all the suggested "still having issues?" I am connected to it via WiFi so I don't get why it's not detecting.
  • michaelkenward's avatar
    michaelkenward
    What Orbi network? (Model number?) Which Orbit app? (iOS or Android?)
    Not much to go on there. What are you doing and where does it go wrong?
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Orbi - NETGEAR Communities
    or
    Nighthawk App - NETGEAR Communities
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
  • It’s an orbi RBR750. Trying to log into the iOS app. While on the Wi-Fi network. Says that network could not be detected.
      michaelkenward
      Still not much wiser. That is the exact wording of the message that the Orbi App throws up?
      Can you get into the RBR750 using the browser graphical user interface (GUI)?
      That would rule out iOS issues. There have been problems with that in the past.
      • Smam_berg's avatar
        Smam_berg
        Sorry I’m not more clear on the issue. Maybe this photo will help a little. I will also try the GUI method and see.
