musiclover360's avatar
Aug 07, 2023
ORBI RBR750
My download speeds is only 65MBs but my upload is 495mbs.  MY Internet provide has a download speed of over 500mbs for me when I log into my ISP and run speed test.  But when I log into the Orbi is 65mbs.    Any ideas?  Is it time to replace the ORBI with something else?
  • FURRYe38's avatar
    How are you speed testing? Wireless or wired ethernet?
    What devices are you speed testing with?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How many RBS are deployed?
    Armor, Smart Parental Controls or Circle, Traffic Meter.
    • musiclover360's avatar
      musiclover360
      Orbi Firmware is V4.6.14.3_2.3.12
      I have two satellites plus the router
      Testing from iPad and from Laptop  over wifi
      I'll turn of Traffic Meter and see if that makes a difference
      • FURRYe38's avatar
        As a quick test, turn OFF the RBS and run speed test with your devices say 10 feet away from the RBR.
        What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
        https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
