TexasPapi
Jun 13, 2025Tutor
Orbi RBR750P Wi-Fi Drops
I bought a new RBR750P with one satellite in April 2025. It's been problematic from the outset, insofar as I am getting random wi-fi drops. Meaning: the SSID disappears from the list of availabl...
- Dec 03, 2025
I had an interesting experience yesterday that I'll share, and I suppose wrap this thread up while I'm at it.
Over the course of...I don't know, a few weeks or a month, I kept getting drop-outs periodically. Annoying but I would just push through. They started getting more frequent toward the end, until yesterday it culminated in me not being able to keep the connection up for longer than about 3 minutes. Literally I'm trying to have a conversation with ChatGPT from my Mac about what's going on and what to do, and I can't because the connection is bouncing so much.
Interestingly, this time it was only happening from my MacBook Pro--I was watching Netflix from my iPad on the same network during the whole process (except when I manually rebooted the router or bounced the power). Which is different from what I recall when I opened this thread, and of course makes me think there must be a problem specific to my MacBook, whether hardware or software. Did the OS get an update that broke it? Is my wireless radio just dying? Have I got a VPN causing a problem? Is there a client-side wi-fi setting I need to change? Is there a router configuration that could stabilize it?
I actually started shopping for an Eero. Then I remembered this conversation, and among the many steps ChatGPT had me try, the same recommendation appeared: shut down Armor. So after going through the mind-boggling mobile UI to find this setting, I shut it down. It was a miracle cure. Immediate relief from the symptoms. Network's been up since then.
So, I'm not sure what to make of this. The fact that my iPad and iPhone behave differently makes me want to give Orbi the benefit of the doubt. On the other hand, Armor on the router seems like it should be a total black box with the same behavior across any client. In any case, I'm sick of dealing with it. Unfortunately it appears I wasted my money on the Armor subscription (of which I've used for maybe 4-6 (painful) months out of the 12, because I won't be turning it back on.
TexasPapi
Jun 13, 2025Tutor
Thank you for your thoughtful reply. You’ll forgive any perceived pushback below. It’s not you, it’s the problem.
Does the front LED on the RBR or RBS turn on PINK or blink any?
On the RBR750P I think the LED is atop the unit. I haven’t noticed anything but I’ll honestly have to take a closer look next time to be sure.
Does this happen if you temporary disable Armor?
I don’t know, I’d have to test that. But as I said in my original post, I’m not keen to do this. I’m assuming/aware you mean just to test, not permanently. But if I find that Armor is behind the problem, this is not helpful to me—I want that functionality and I’m paying an incremental subscription price for it. Netgear needs to test that, not expect me to lose paid functionality in the meantime.
What is the distance between the router and satellite(s)? 30 feet or more is recommended…
I have one satellite, it is upstairs while the router is down, so I imagine more than 30 feet away. But I also don’t understand the relevance, if we are talking about an SSID that drops completely, and devices that are previously connected to the router, not the satellite.
Might try the RBR out in an open space instead of a closet area. This may inhibit good wifi signal travel.
I appreciate the suggestion but I’m not going to do this. The router is less than 20 feet from the devices mentioned here, with open doors in between. What I meant buy “closet” is a fancy Leviton wall-mounted network enclosure of thin plastic, specifically constructed to be porous for wi-fi signals, and my previous router (also an Orbi) did not have this problem in the same setting. That’s where I want the router to be, and I can’t fathom how the current location is problematic for any self-respecting router. I also don’t understand why strength of wi-fi signal would matter, if there is no wi-fi network to connect to at all?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
The 2.4Ghz channel is Auto. The 5g channel is 40 (I read something previously with the same suggestion, and made that change some time back). All the devices I’ve mentioned here are connecting to the router (not satellite), on the 5g (not 2.4g) channel.
Be sure to disable any MAC Address randomizers on phones and pads while at home
This is set to “Fixed” on my MacBook and iPad presently, for my home network. So it’s not actually “off” per your suggestion, but it does mean the MAC address is unchanging on this network. The router doesn’t seem to be having any problem identifying my device. For example, it appears consistently in the device list, with the same MAC address and the same device model, name, and type. I can look into this but—leaving room for my own ignorance or misunderstanding—how is an unchanging client-side MAC address causing the router to drop wi-fi, and stop broadcasting SSID, for multiple connected devices, all at the same time?
I’d be more keen to test client-side settings and whatnot if the network was up, or if I had issues that differed across devices, at least in terms of timing of recurrence. As it stands, it’s hard for me to imagine this issue being anywhere but in the router.
Jun 13, 2025Guru - Experienced User
Well we can't know for sure if Armor could be at fault or not unless you give it a try. If it is a prblem then we can let NG know about that so they can fix it. Try this will either help rule out Armor or point to it as a culprit. It won't bother anything if Armor is disabled for a few days either.
Id also turn off the RBS to help rule anything out there. RBS is doubtful being the culprit.
Last resort would be a factory reset and setup from scratch, with out Armor being enabled first, then if nothing is seen, then enable armor and continue to check for this issue.
All of these questions and suggestions are to help narrow down and figure out where the problem maybe, in router or else where. Gotta start some place.
- TexasPapiJun 13, 2025Tutor
Yes, I understand, it's just grinding my gears. It's too much for Netgear to ask customers to sacrifice functionality in order to test this for them. This product's been in place for over a year, and I can't be the first one to have reported this problem.
I do have one other hypothesis that would be exculpatory if true. I wonder if a short power blip, on this circuit alone, could cause the router to reboot unexpectedly. It's not without precedent, I've in the past had a fuse in my garage on a particular circuit that I'd occasionally find flipped to the off position. No reason I could detect. Fuse wasn't blown. I'd just open my garage door and find that it was on battery power instead of circuit power, and flip the fuse back on. However, the flaw in this logic and that evidence is that power would stay off that circuit, until I flipped the fuse back manually. That's not what's happening here. Anyhoo.
- FURRYe38Jun 14, 2025Guru - Experienced User
Not trying to ask customer to sacrifice functionality. When users come to the forums for help and problems, we have to go thru some troubleshooting steps to see where the real issue is. This is all appart of the troubleshooting process to get to the issue or maybe resolve the issue if we can. Once we can figure this out then we can get this to NG if this is beyond our help.
If users don't want our help or can't follow troubleshooting steps, then we ask that you reach out to NG support and have them help you out.
I do have one other hypothesis that would be exculpatory if true. I wonder if a short power blip, on this circuit alone, could cause the router to reboot unexpectedly. It's not without precedent, I've in the past had a fuse in my garage on a particular circuit that I'd occasionally find flipped to the off position. No reason I could detect. Fuse wasn't blown. I'd just open my garage door and find that it was on battery power instead of circuit power, and flip the fuse back on. However, the flaw in this logic and that evidence is that power would stay off that circuit, until I flipped the fuse back manually. That's not what's happening here. Anyhoo.- TexasPapiJun 15, 2025Tutor
OK, I've turned on hourly log email sends per CrimpOn's suggestion, to see if we can see something. I'd use the existing log but it seems it has a 24-hour loopback window, so I've lost whatever is there. Can't say I'm holding my breath, the log doesn't look very detailed. I've left the router/Armor config as-is for now, so we're not changing the conditions of the experiment. But if we get nothing from the log, I'll disable Armor and we'll do it again.
