TexasPapi
Jun 13, 2025Tutor
Orbi RBR750P Wi-Fi Drops
I bought a new RBR750P with one satellite in April 2025. It's been problematic from the outset, insofar as I am getting random wi-fi drops. Meaning: the SSID disappears from the list of availabl...
- Dec 03, 2025
I had an interesting experience yesterday that I'll share, and I suppose wrap this thread up while I'm at it.
Over the course of...I don't know, a few weeks or a month, I kept getting drop-outs periodically. Annoying but I would just push through. They started getting more frequent toward the end, until yesterday it culminated in me not being able to keep the connection up for longer than about 3 minutes. Literally I'm trying to have a conversation with ChatGPT from my Mac about what's going on and what to do, and I can't because the connection is bouncing so much.
Interestingly, this time it was only happening from my MacBook Pro--I was watching Netflix from my iPad on the same network during the whole process (except when I manually rebooted the router or bounced the power). Which is different from what I recall when I opened this thread, and of course makes me think there must be a problem specific to my MacBook, whether hardware or software. Did the OS get an update that broke it? Is my wireless radio just dying? Have I got a VPN causing a problem? Is there a client-side wi-fi setting I need to change? Is there a router configuration that could stabilize it?
I actually started shopping for an Eero. Then I remembered this conversation, and among the many steps ChatGPT had me try, the same recommendation appeared: shut down Armor. So after going through the mind-boggling mobile UI to find this setting, I shut it down. It was a miracle cure. Immediate relief from the symptoms. Network's been up since then.
So, I'm not sure what to make of this. The fact that my iPad and iPhone behave differently makes me want to give Orbi the benefit of the doubt. On the other hand, Armor on the router seems like it should be a total black box with the same behavior across any client. In any case, I'm sick of dealing with it. Unfortunately it appears I wasted my money on the Armor subscription (of which I've used for maybe 4-6 (painful) months out of the 12, because I won't be turning it back on.
TexasPapi
Jul 22, 2025Tutor
Well, I give up. Prior to this post, I'd reset the router multiple times, and it was recurring at a completely intolerable frequency nonetheless. Ever since I put this post up, this problem has not recurred. I have no idea how one explains that, as there's been no configuration change on my side, but for enabling log emails daily, which of course tells us nothing when the problem doesn't recur. So, I've disabled log emailing and put this on the back burner.
Jul 22, 2025Guru - Experienced User
I recommend that you make contact with NG support and see what your RMA options are. Maybe a faulty system from the get go since you mentioned having reset the system multiple times and issues are still happening. Ask aobut a cross shipping RMA option.
I see there hasn't been any FW updates and not sure if this system will see any thing.
- TexasPapiJul 22, 2025Tutor
Maybe I wasn't clear. The problem is not recurring presently.
- FURRYe38Jul 22, 2025Guru - Experienced User
Ah ok, my bad, I read that wrong. So system has been working good for you in the last month?
