benjaminoerskov
Jan 26, 2026Aspirant
Orbi RBR850 / RBS850 – Constant IoT disconnects (Shelly, robot vacuum, etc.)
I’m experiencing persistent instability with my Orbi mesh network and IoT devices, and I’m hoping someone can help confirm whether this is a known issue or if there’s something fundamental I’m missin...
benjaminoerskov
Jan 29, 2026Aspirant
The reason that Im asking is, that when I initially set this up, it was working great for months. Until suddenly they started dropping constantly.
Correct, I have only one RBS online atm.
I dont see an option to change power for single unit, just change it for 2.4 or 5 GHz.
After factory reset, it is now back to 100% for both.
Jan 29, 2026Guru - Experienced User
The power change seen on the RBR is for the entire system, both RBR and RBS. Can try 50% with the RBR and RBS to see if anything changes.
Possible some changes at the SW/FW level on those devices as well on how they handle wifi signals.
