villot418
Nov 25, 2021Aspirant
Orbi rbr850 goes offline daily sometimes twice per day
I have an Orbi RBR850 with 2 satelites. This setup ran pecfectly since mid 2020 until October of 2021. The Orbi goes offline daily, I get no wifi or wired connections. I can access the orbi from my phone app (shows offline) and reboot or plug the orbi out and back in. Usually there is a solid magenta light on the front of the Orbi. After the reboot I am usually good for 24 hours. I did a factory reset before, that didnt help. Firmware v4.6.3.16. Spectrum came out and found no issues going to the modem, they even replaced the cable going to the house. I don't reboot the modem to get reconnected only the Orbi.
setup:
ISP Spectrum --- personal modem (Netgear CM1100) ---- RBR850 --- 2 satelites
Any help will be appreciated.
Does the front LED turn ON on the RBR when this happens?
Power OFF the RBR and ISP modem fo 1 minute or more then back ON.
Has a factory reset and setup from scratch been performed since last update?
- villot418Aspirant
Yes the led light turns to solid magenta
I don't power off the modem, I only power off the Orbi
Yes I performed a factory reset, that did not help
If the front LED turns on PINK, means it lost it's connection with the ISP modem:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
I would have the ISP check for anything seen on there logs around the time frame when this happens.
