LukeM's avatar
LukeM
Star
Jul 28, 2020
Orbi RBR850 WiFi - SSID Not visible on some devices
I have an Orbi 6 Mesh Router with Firmware version 3.2.15.25_1.3.15. I have two sattelites and the install was fairly staightforward. However, since, day 1, the Orbi does not show up in the SSID list...
  • Mikey94025's avatar
    Jul 28, 2020
    Use the admin browser (orbilogin.com), go to Advanced... Advanced... Wireless Settings, change CTS/RTS threshold for both 2.4Ghz and 5Ghz to 2347.  This corrects many wireless compatibility issues.
    If that doesn't work, in the worst case you can uncheck Enable AX in Advanced... Setup... Wireless Setup.  But it would be a shame to disable AX on your new AX router just to remain compatible with older devices.
