steveshead
Oct 10, 2022Guide
Orbi RBR850 will not connect to Starlink
I know there are a lot of other posts on this subject, but they all lead to a solution of adding a switch in between the Orbi and Starlink - which did not work for me.
Things I've tried:
- Putting Starlink in bridge mode and connected Orbi to the Starlink network adapter - didn't work.
- Not putting Starlink in bridge mode and connect Orbi to the Starlink network adapter - didn't work
- Purchased a GS108T - connected it to Starlink and Orbi to it using Orbi "Internet" port - didn't work
- Purchased a GS108T - connected it to Starlink and Orbi to it using Orbi normal port - didn't work
- Remove all other connections from Orbi and just connect from Orbi to the Starlink network port - didn't work
The only time I thought I got close was when I moved all network cables from the Orbi to the switch - then connected from a normal port on the Orbi to the switch - it worked for a few minutes then died - Starlink kept going offline.
If you have successfully used a switch in between Orbi and Starlink could you take pictures of the ports for both and send them over. I might be connecting it wrong.
I'm not sure what else to try. I am not a defeatist so will continue to ponder this. If anyone has any further thoughts and/or ideas please send them over. Orbi is awefully expensive for it to not work with Starlink.
Cheers
Steve
Did you try connecting the orbi to the starlink but put the orbi in access point mode? (have starlink in router mode)
Good point - I have not - I'll try that this evening. Does it matter which port I use on the Orbi, since one is labelled internet?
Oh jeez - I just noticed that I have the PPPoE username and password configured for the current ISP ...sigh. I'm going to reset that to not require a login and see if that allows me to connect in bridge mode, if not perhaps the switch will work this time.
Question on the port though. I have two available ports for the external connection:
- Internet port (2.5Gbps)
- WAN aggregation (2.5Gbps + 1 Gbps, LACP-IEEE802.3ad)
Does it matter which one I select?
Cheers
Steve
