Sufferingbearsf
Feb 05, 2025Aspirant
Orbi RBR850
I purchased the RBR850 with 2 satellites. I could not get the install to work with my iPhone, so I used a laptop. I installed the router and was installing the satellites when the solid white light on the router went out. So i powered everything down and plugged it back in, blinking white, then no light.
So I hit the reset briefly and it did the same thing. Someone suggested to me that the firmware might be corrupt or need an update. So I held the reset button in for a longer time to restore the router. I started again, got to a point where I could update the firmware, it was going along and then the light went out again.
Any ideas before I return this thing. I'd be more confident but I had install issues with the first one that we bought and Netgear gave up. Either i have some kind of bad luck or I don't know what
Front LED when OFF means the RBR and RBS are working normally:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
