SDshaun
Dec 09, 2020Aspirant
Orbi RBR853 Satellites show disconnected but are working over Wifi.
Satellites are hard wired over CAT6. Been working okay but noticed connection issues with devices connected to the satellites yesterday. The network showed the satellites as all being disconnect. Rebooted and all the attached devices seem to work okay now but network still shows the satilittes as disconnected.
When viewing Attached Devices it shows all Devices in the network but everything is listed under Main Router, nothing under the satellites. Also all devices show as Wired, even the ones that are WIFI and likely connected to the satellites.
Firmware V3.2.16.22_1.4.9 as listed on the Web UI.
Can't conform the firmware for the satellites as they are not showing up. (So not sure what they have but likely up to date)
Rebooted the router many times and still the same.
Recently did a factory rest on another issue (Could not connect to the router Web or APP, unless rebooted every few days.) so its been reset recently but was working until it wasn't.
Did not reboot or do anything with the satellites mostly because they are in locations like the attic which are hard to get access.
So frustrating that this always needs something rebooted or fixed.
Are you seeing this on the Orbi app or on the RBRs web page?
When you connected the RBS to the RBR, did you first sync them to the RBR wirelessly, THEN after they were sync'd, connect them via ethernet?
Is there a ethernet switch in the configuration between the RBS and RBR?
- SDshaunAspirant
Hi thanks for the questions, and answers below.
Cox and the Arris CM820
Currently both
Yes, I did do that, had them working wireless for a couple days when I first installed them before hardwiring them.
There is, its Dlink 24 port and one of the satilittes first hits a Dlink 8 port then to the same 24 port. (I just power off and on the 24 port just for fun but didn't see a change.)
What are the model #s of these switches.
What happens if you take both RBS to the same room or near the RBR and with a ethernet cable, connect them behind the RBR directly?
