JHRucker's avatar
JHRucker
Orbi RBRE 960 drops WiFi clients several times a day
I recently installed a Orbi WiFi 6 RBRE960 router with two satellites.  Both the satellites are connected over hardware backhaul. WiFi clients connected to both satellites randomly are dropped throughout the day.  I would say about every hour or so.  The only thing I see strange in the router logs are a continuous flow of DHCP address assignments.  Seems to happen right after the WiFi clients are dropped.  Anyone else seeing this?  Any thoughts?
Hardware Version RBRE960
Firmware Version V6.0.3.85_3.1.15
GUI Language Version V3.0.2.11_2.1.30.3
Operation Mode Router
LAN Port
IP Address 10.50.0.1
DHCP On
  • Update.  I was able to get the connection between the Satellites and Router to be stable by switching from a hardwired backhaul to wireless backhaul.  It is about 90% more stable now but still has a few issues.  My "far away" satellite works great when it shows it is connected to the "not so far away" satellite for its connection.  But randomly the "far away" satellite will connect directly to the router and it shows a poor backhaul status.  I have no clue why it does this, there are no power outages or anything that I can tell would cause the backhaul connection to change.
    Anyone else seeing this?   I think I will post this as a new issue.
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Is the separate 6Ghz and IoT SSID broadcast enabled or disabled?
    What devices do you have connected?
    Are the RBS directly connected to the back of the RBR or is there a LAN switch in between.
    What is the brand and model# of the switch being used?
    Are you using he 2.5Gb LAN ports or the 1Gb LAN ports to connect the RBS to the RBR?
    What CAT# lan cable are you using?
    • JHRucker's avatar
      JHRucker
      Thanks for the reply.
      I don't think my issue is a signal strength problem.  Wireless devices show full signal strength.  They just loose connection.  When I look at the iPad's WiFi setting (during the disconnect) the WiFi SSID is completely gone from the list.  After a few moments it reappears and connects and works fine.  What's a bit concerning is in addition to my SSID reappearing, I also see the NetGear's default IOT and Guest SSIDs appear in the available WiFi networks.  The are there for a minute or two and disappear.  I do not have those enabled!  It almost appears as if the orbit satellite is rebooting or something??
      My two satellites and router 2.4g ports, are plugged into a switch.
      We live in a very rural setting no other WiFi hubs around.
      • FURRYe38's avatar
        Will be good to give feedback to the questions presented please so we can better help you out.
    • FURRYe38's avatar
      • Psychopasta's avatar
        Psychopasta
        I have a 950-based system, and I recently switched it from Router mode to Access Point mode so that my cable modem is now providing DHCP services to my entire Local area network. This has greatly improved stability of my network.
        Previously when I looked at the router logs it was giving out IP addresses over and over, and my network was subject to random glitches. So I moved to access point mode and have seen a much better stability (100% as measured by NetUptimeMonitor on a PC with a wireless connection).
        I imagine that the Orbi is running some form of Linux, so I'm surprised that disabling DHCP has had such a big effect. Maybe you could try that too and see what happens.
        - Mark
