sfgtsfn's avatar
sfgtsfn
Orbi RBRE 960 shows out of sync with satellite, even though i have devices connected to satellite
could not get sync to work, however I did get blue light and devices are connecting to satellite.  just shows OOS and everytime I try to resync is says attempt failed.  both devices have same firmware, been reset and are only 20ft away.  is this just a software issues or something i should be concerned with?
  • FURRYe38's avatar
    What browser are you using?
    How are you resetting the system? Are you resetting and setting up from scratch both on the RBS and RBR?
    • sfgtsfn's avatar
      sfgtsfn
      chrome, v6.3.7.10, I have reset both and started from scratch.  xfinity internet CGM4981COM is modem
      • FURRYe38's avatar
        How are you setting up the system after a FR? Web browser and setup wizard, adding RBS using the RBRs Add Satellite option or Orbi app?
        Do you see a Generation Backhaul Password button under Advanced tab/Advanced/Wireless settings on the RBRs web page?
