MP_OC
Feb 15, 2024Aspirant
Orbi RBRE960 500 Internal Server Error when Applying Changes to Logging Options
I get a 500 internal server error after pressing the Apply button to save chances on the logging admin page. Any ideas what may be causing this and how to fix it? RBRE960 — Orbi Quad-band Mesh Wi...
- Feb 15, 2024
What browser are you using? Happens in MS Edge, Firefox or Opera?
FW is behind. Might update and see if this still happens:
CrimpOn
May 11, 2024Guru - Experienced User
MP_OC wrote:
when I browse to the file (that I used to upgrade the router),
The image file for router and satellite are different.
https://kb.netgear.com/000066069/RBRE960-RBSE960-Firmware-Version-7-2-6-31
MP_OC
May 11, 2024Aspirant
CrimpOn - You are correct. I completely missed that. I forgot the satellites and routers aren't interchangeable and have different product numbers. That worked and saved me having to back track. Thanks!
- FURRYe38May 11, 2024Guru - Experienced User
All up and running now?
- MP_OCMay 13, 2024Aspirant
All good now. Original issue of internal server error 500 for log option changes is solved and the firmware is all up to date on router and satellites. You were both very helpful. Thanks again!
- FURRYe38May 13, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
