Retired_Member
Jul 17, 2023Orbi RBRE960 DC Cable Extension?
Dear community, I have the new RBKE963 Orbi system. Now there is a power adapter DC (19V 3.16A). But since the cable is too short and an extension simply with a Schuko plug does not work structurally, I'm trying to extend the DC cable by 1 meter. Can anyone tell me a source where to get something like this? It's easy to get 5,5mmx2,1 and 5,5 x 2,5mm DC extensions, but they don't fit because they are too small. Does anyone know the specifications of the power plug? It doesn't say anywhere. Thanks and greetings
- Retired_Member
Thanks, but I meant the other side, so the small dc plug. I am assuming it is something like 5,5mm x 3mm but not sure. I have to extend the cable not at the power supply side. I hope it is now clearer. Thanks
They don't.
The plug is a special type and size of plug. 7.7mm with no center pin. Easier to extend the power adapter side.
