MP_OC's avatar
MP_OC
ORBI RBRE960 Solid Red Light
What does a sold red connection status light on the Orbi RBRE960 mean? I've had intermittent connection issues and now it is totally down and unable to connect to my network and keeps returning to the solid red light after rebooting and flashing white for a while.
  • FURRYe38's avatar
    Is this the front LED on the RBR?
    https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    Most likely the RBR is failing to get a good signal from the ISP modem or ONT.
    The ISP need to check the signal line up to there modem or ONT and ensure all is good there and the modem or ONT is in good working operation.
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    • MP_OC's avatar
      MP_OC
      It's the front LED showing connection status that's Red. The power LED on the back is Green. The page showing what colors mean doesn't list that color for the front LED.
      I've checked all the cables and connections. The modem is good and all ISP tests look good. A different router works fine with the modem.
      I'm running latest firmware on the router and satellites v7.2.6.31.
      I've done a factory reset on the router and that got it working again.  However, now I can't get the satellites which are hard wired to sync. I'm probably going to have to do factory resets on those unless I figure something else out.
      Weird thing about the satellites is that when the router found them, their SNs in the app don't match what's on the labels, but the mac addresses do match.
      This has all been working fine for months except for some intermittent connection issues during the past week. And then this morning found the solid Red LED on and no internet connection. No number of resets or power cycling did anything, but the factory reset at least got the router working again.
