BradPruitt's avatar
BradPruitt
Initiate
Feb 04, 2021
Orbi RBS50y V2 wont sync with Rbk752
I am having trouble syncing the outdoor satellite to the new router.
Does the RBK752 and the RBS50Y have compatiblity?
  • From what I userstand, the RBSY needs to have Extender mode FW loaded on it, then it should work with Orbi AX systems.
  • FURRYe38's avatar
    • BradPruitt's avatar
      BradPruitt
      Initiate
      Thanks, I was going to try that if nothing else worked, but it worked perfectly!
      • FURRYe38's avatar
        Good to hear. Enjoy. :smileywink:
