janhillebrand
Sep 21, 2025Tutor
Orbi RBS750 disappeared
Dear community, I use 1 Orbi RBS750 satellite with my NBR750 router running firmware v4.6.5.11_1.5.66. Recently, I updated my Orbi RBS750 satellite to firmware v7.2.7.15. The satellite kept c...
Sep 21, 2025Guru - Experienced User
If you press the reset button the RBS for 15 seconds then release, watch the back power LED, should be amber then turn GREEN. When it turns GREEN power it OFF.
Press the reset button on the NBR for 15 seconds then release. Leave the NBR ON. Give 2-3 minutes then power ON the RBS. Give about 3-5 minutes, the RBS should auto connect to the NBR and front LED should turn BLUE. If it does, walk thru the setup wizard on the NBR usng a wired PC and web browser: https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
During the setup wizard the process should find the RBS and then continue to complete the setup wizard and get to the home screen.
Do this with the RBS in the same room as the NBR.
