caomoss
Sep 16, 2025Aspirant
Orbi RBS750 firmware update failing
 I purchased an add-on satellite for my Orbi 750 system and am having trouble getting it connected to the router. I've learned from similar posts that this might be resolved if I update the firmware o...
- Sep 16, 2025If you can access the new RBS web page with a web browser, try stepping into newer version of FW by trying to install v4.6.3.7 from the Previous Versions selection at the bottom of the download page here: https://www.netgear.com/support/product/rbs750/#download See if this gets the RBS up to v4 first.
Sep 16, 2025Guru - Experienced User
