Mstrbig
Jul 28, 2021Master
Orbi RBS750 Satellite continuous pulsating white light
I have a situation where an Orbi RBS750 satellite is stuck on pulsating white. I have performed all the normal steps to fix this.
Performed a reset and still pulsating white. This malfunction happened after the satellite received automatic firmware update 4.6.3.7. The RBR750 router and other RBS750 satellite seem to be working fine.
Any input will be appreciated.
What happens if you log in to the RBS web page. Still keeps pulsating?
Check the status on the RBS web page to see if it's fully synced an SSID and WPA modes are correct...
Remove the RBS from the RBRs web page then re-sync again?
- MstrbigMaster
FURRYe38 wrote:What happens if you log in to the RBS web page. Still keeps pulsating?
That's the other strange thing.
When I plug a net cable in and log in to the RBS web page, it accepts username and password, then never fully populates the GUI home page. When I remjove the RBS from the RBR's web page, it cannot find the satellite when syncing.
After removing the RBS from the RBRs web page, reboot the RBR and after it's back to ready, press the sync button on the RBS then RBR?
